Results 1 to 5 of 5
Thread: Leaking shock? Or something worse?
    May 2020
    Default Leaking shock? Or something worse?
    I swapped my winter wheels to my summers today and I felt pretty darn proud of myself. Until I noticed a leak! My right rear shock looks pretty oily, but there's also oil staining further down on the lower near the wheel. See pics.
    Could the staining just be from the shock leaking? Or should I be looking for a leak somewhere else?
    Default Re: Leaking shock? Or something worse?
    likely just the shock. Maybe check your motor mounts as well,just to be safe.
    Definitely the shock.
    @S.F.W - I think he mentioned it was in the rear of the car, so motor mounts would not be suspect.
    Missed that, good catch.
    Sent from my SM-G986W using Tapatalk
    Hey, no problima.
    Ami just noticed this month is my 15th year as an "active" TM3 member, do I get a chocolate or something? ; )
  1. Replies: 44
    Last Post: 12-19-2014, 10:28 PM
  2. Leaking Rear Shock - Knocking Over Bumps
    By nrajput in forum MazdaSpeed3 Brakes and Suspension
    Last Post: 11-02-2014, 08:45 AM
  3. Rear Shock Install BC Coilovers/Stock Upper Shock Mounts
    By MDMaz3 in forum Suspension & Brakes
    Last Post: 02-06-2013, 11:51 PM
  4. Blown/Leaking Shock?
    By Skip in forum Suspension & Brakes
    Last Post: 01-06-2013, 08:15 PM
  5. Right rear shock leaking
    By Turok in forum Suspension & Brakes
    Last Post: 01-03-2012, 07:39 PM
