I have a 12 Mazda 3 with a/c, auto non sky, 125000km. About 3 months ago it developed a clunking noise going over bumps, while driving under 40km/h. Over 60km/p there it no noise.
Things that have been replaced or done since noise started as there were worn are as follows:
An alignment x 2 as was out before everything and was out after replacing everything
Both front struts, mounts, coils
Both outter tie rods
Both sway bar bushings
Both sway bar links
Both front control arms with ball joints
Drivers wheel bearing
Retorqued every bolts touched
Can a CV joint or drive axle cause a clunk? Have no clicking sound turning but seems to be play and tensions while driving. Or wheeling bear?
Was going to remove sway bar links and see if noise goes away to test to see if links are faulty.
But don't know what else could make noise at low speed and not at higher speed.
Any ideas will be greatly appreciated.
