Results 1 to 5 of 5
Thread: battery bracket nut broken when replacing battery
    May 2014
    Default battery bracket nut broken when replacing battery
    Hello I replaced the battery on my 08 M3 GT today. When I opened the cover I discovered that the metal bracket holder nuts were extremely rusted on both sides. I applied some penetrating lubricant. I was able to remove one of the nuts successfully but the second one broke off. Is it possible to replace that metal screw that the nut holds on to or do I have to replace the whole battery box/tray? (Please refer to the image).
    Should I leave it just held by one side? other recommendations?
    When removing the negative terminal the nut that holds terminal tight to the battery post also broke off. Luckily the part that its still there is holding the bracket tight but I want to replace it. What part number is that screw/nut?
    Thank you for any help/suggestions
    Default Re: battery bracket nut broken when replacing battery
    No image !
    But if the bolt and nut can be removed entirely why not replace with a something that fits from Home depot.
    Or replace both with new stainless steel
    May 2014
    not sure why it didn't upload here goes again
    May 2014
    not sure why the upload site that I'm using doesn't work
    May 2014
    this is the other nut/bolt that broke
  1. Any suggestions, tips, caveats on replacing '14 battery?
    By Google in forum Mazda3 General Discussion
    Last Post: 10-26-2019, 07:45 PM
  2. Do I need a new Battery? (Battery test results)
    By TheAnswer_03 in forum Electrical
    Last Post: 11-10-2018, 02:42 PM
  3. CEL on after replacing sparkplugs and battery at 105km
    By justmazduh in forum Problems with the Mazda3
    Last Post: 12-05-2016, 11:55 PM
  4. CEL on after replacing battery
    By iAaronx in forum Engine & Drivetrain
    Last Post: 11-14-2015, 04:36 AM
  5. Slim Battery Tray: What 51R battery to get?
    By pwdunmore in forum MazdaSpeed3 Modifications
    Last Post: 11-09-2012, 02:51 PM
