I have a 2005 Sport GT that I purchased used a few years ago. I'm in the process of refreshing any worn suspension components at the moment and I've discovered that I don't have stock front or rear sway/stabilizer bars. Referring to the sway bar sizes thread, I see that my bars are likely either Eibach or stock MS3 as they measure 26mm front and rear. They're finished in red, so I suspect the Eibach. To be more confident, can someone confirm the BK Mazdaspeed3 sway bars are black? I want to replace the bushings, but obviously the ones intended for the stock 21/20mm bars aren't going to fit. Eibach seems to have removed all information about sway bars for the BK from their website. If these are Eibach sway bars, should I be safe ordering bushings for a 2007 MS3 since it would have stock 26mm bars? Thanks for any insight or advice.
