Results 1 to 4 of 4
Thread: Went for an oil change, 5w20 was put in instead of 0w20
    Jr Member ptgrad2012's Avatar
    Aug 2012
    Default Went for an oil change, 5w20 was put in instead of 0w20
    Hi all,
    Took the car in for an oil change for 2012 Mazda 3 GX non-sky.
    Check the receipt the next day found out 5w20 was put in.
    Should I be concerned, and would there be any immediate risk of any damage?
    thanks
    Default Re: Went for an oil change, 5w20 was put in instead of 0w20
    No ///the thicker oil is better for the winter
    Besides ...as your engines adds on the miles and there is more wear in the cylinder rings
    the gage increases to were a slighter thicker oil here keep compression,
    Worst case the 5w is thicker and not as slippy as the 0W
    What does the dealership say ... are they aware?
    Aug 2012
    yeah, brought it back, got drained and filled it back with 0w
    Jr Member Flunk's Avatar
    Dec 2009
    2021 CX-30 GT Turbo
    The 2010-2011 Mazda 3 GX, with exactly the same engine and transmission was rated for 5W20. That's probably why they made the mistake. Wouldn't have made a difference.
  5. The Following User Says Thank You to Flunk For This Useful Post:
    G ~ MINI (12-16-2021)
  1. Mobil 1 0W20 users - how often do you guys change your oil?
    By Hotsky in forum Mazda3 General Discussion
    Last Post: 03-21-2015, 03:43 AM
  2. Mobil 1 0W20...where can I get it?
    By Gen1GT in forum Engine & Drivetrain
    Last Post: 12-06-2011, 01:52 AM
  3. 0w20
    By krimsalt in forum Engine & Drivetrain
    Last Post: 12-02-2011, 01:37 PM
  4. 0w20 - where to buy
    By Walrus in forum Engine & Drivetrain
    Last Post: 06-07-2009, 05:20 PM
  5. Royal Purple 5w20 or Mobil1 0w20?
    By MajesticBlueNTO in forum Mazda3 General Discussion
    Last Post: 08-27-2004, 01:25 PM
