Results 1 to 3 of 3
Thread: 2021 Mazda3 Turbo Oil Consumption
    Mar 2022
    Default 2021 Mazda3 Turbo Oil Consumption
    Some vehicles may have a LOW ENGINE OIL LEVEL warning message and a CHECK ENGINE light illuminated in the instrument cluster, along with DTC P250F:00 stored in memory. DTC P250F:00 - Engine oil level signal: engine oil level low. Upon inspecting the engine oil level, the level is found to be low and there doesn't appear to be any trace of oil leakage in the engine compartment. This concern usually occurs when the mileage reaches approximately 5,000 - 7,500km and may also occur again after replacing or topping off the engine oil. The root cause of this concern has not been identified yet, therefore a repair procedure will be announced at a later date. Since this issue has been reported after a valve stem seal modification, it is very likely that valve stem seal damage is causing oil to leak into the combustion chamber.
    NHTSA ID Number: 10202685
    Manufacturer Communication Number: 01-012-21-3832
    5 Affected Products
    Vehicles
    MAKE MODEL YEAR
    MAZDA CX-30 2021
    MAZDA CX-5 2021
    MAZDA CX-9 2021
    MAZDA MAZDA3 2021
    MAZDA MAZDA6 2021
    Mar 2017
    Default Re: 2021 Mazda3 Turbo Oil Consumption
    I will alert my neighbor about this. Thanks
    There is alot talk about this on the Mazda 3 Revolution Forum
  1. Turbo AWD Mazda3 for 2021
    By Captain Mazda in forum Mazda Canada - Conversations about new releases
    Last Post: 11-30-2020, 11:14 PM
  2. 2021 Mazda3 Turbo Full Reveal
    By MazdaCanada in forum Mazda Canada - Conversations about new releases
    Last Post: 08-04-2020, 09:34 AM
  3. 2021 MAZDA3 TURBO: REFINED PERFORMANCE
    Last Post: 07-18-2020, 09:21 AM
  4. Turbo Kit for Mazda3 available
    By hiboost in forum Engine & Drivetrain
    Last Post: 11-16-2015, 03:45 PM
  5. Excessive fuel Consumption on my 2.3 mazda3 Gt sport 2007
    By joeylips in forum Problems with the Mazda3
    Last Post: 04-24-2011, 12:24 PM
