Some vehicles may have a LOW ENGINE OIL LEVEL warning message and a CHECK ENGINE light illuminated in the instrument cluster, along with DTC P250F:00 stored in memory. DTC P250F:00 - Engine oil level signal: engine oil level low. Upon inspecting the engine oil level, the level is found to be low and there doesn't appear to be any trace of oil leakage in the engine compartment. This concern usually occurs when the mileage reaches approximately 5,000 - 7,500km and may also occur again after replacing or topping off the engine oil. The root cause of this concern has not been identified yet, therefore a repair procedure will be announced at a later date. Since this issue has been reported after a valve stem seal modification, it is very likely that valve stem seal damage is causing oil to leak into the combustion chamber.
NHTSA ID Number: 10202685
Manufacturer Communication Number: 01-012-21-3832
5 Affected Products
Turbo Vehicles made before October 2021
MAKE MODEL YEAR
MAZDA CX-30 2021
MAZDA CX-5 2021
MAZDA CX-9 2021
MAZDA MAZDA3 2021
MAZDA MAZDA6 2021
